Everything posted by dirtbike23
front driver side brake hose leaking, replaced both sides, had to weld nut on banjo bolts' head since it is already rounded off perhaps during removal (previous owner).
Free is for me my 1995 wd21 budget build
dirtbike23 replied to Justinschluter's topic in 90-95 WD21 Pathfinders
with my new coil able to gain around 25-30mm of lift -
replaced my coil spring, able to gain at least 25-30mm of lift.. how she's with the new spring and a cranked TBs...
RCWD21 thanks for the feedback sir, think ill go with the ironman or king brand as thats the only available on my place, been reading some reviews on those but not much info i could have.
RCWD21..nice, am also planning of having my coil replaced with Ironman brand, got any feedback on this brand. finding JGC springs here is impossible.
just used rattle can type paint so i just can retouch it whenever it needs to. rim is pro comp 97-5884 rock crawler..heres what happened to my knock-off rim. 3 pcs of it had crack..
pulled out tire carrier and repainted it
also replaced upper bumpstop, had to cut some mm to have more clearance
replaced my cracked wheel (knock-off) with pro comp steelies
nope...its a four banger, TD27, diesel...
new rad, new water pump, after couple of days head gasket leaks....had to take off head and replaced.
fender trimming how she looks in 32s
I believe that's a radar mt r5..32/11.5/15..just Installed on mine but I had to trim the fenders about 2" to avoid any rubbing when cornering...havent tested it yet on Offroad..
trimmed fender and installed 32s on 15" wheel
try NTCP or Terrano Club Philippines at FB page
try searching at fb page, they do offroading at mt pinatubo
welcome! happy new year.. there are couple of terrano/pathfinder owners leaving in your area who are a member of Nissan Terrano Club of the Phils..
open or lsd? kindly ID my rear diff, WD21 terrano TD27 NA, manual
dirtbike23 replied to dirtbike23's topic in The Garage
Absolutely sir...really learned a lot in here though mine is diesel but other aspect shares the same with the pathfinders -
nice reading here.learned a lot...thanks guys..drive safe -
seems mine is LSD but acting like an open...thanks for the pic sir... -
you can lock it permanently by removing some internal parts...brake, washers, spring but it will continously spin your cvs and front diff..
wben you took it out (autohub) were you able to assembled it right? i damaged 2 sets of Autohubs before thus i shifted to manual
its mica blue sir..
