Everything posted by PathfinderProject1988
TBI Component Listing & Loctaions
PathfinderProject1988 replied to MY1PATH's topic in 86.5-89 WD21 Pathfinders
I'm having a similar problem, if you find anything out please share!! -
Air Injection Valve (AIV)
PathfinderProject1988 replied to PathfinderProject1988's topic in 86.5-89 WD21 Pathfinders
I'm gonna do exactly what you did there, capping them off. Thanks for all the help! -
just replaced both injectors, still not running right so we took a look and the injectors seem to be stuck open, but theyre both new. could this be a wiring problem? and i cant rev over about 2300rpm also does the temp gauge hook up below the right manifold? saw a plug just laying there not hooked up..
Help Disconnecting Fuel Inj. Wiring
PathfinderProject1988 replied to mikestewart395's topic in The Garage
where the wires com e off the injector and go into the clip thing the back of it should pop off and you pull the injector wires out from that end of the deal (im a little late on getting here) but i just replaced a injector on my 88 a week or so ago, did you get a refurbished one or new one? -
Idle problems
Today I put new wheel cylinders in and new calipers on and the light went out. Something was just pestering it I suppose, another question, brake related After we got done bleeding the brakes we went for a spin around the yard, pedal brake pedal froze up and hit the floor, took off the vacuum line off the booster and it became free, I suppose this means I need a new booster? She started to idle today after we took apart the throttle body because one injector isn't working. After having replaced the other one so we tried to use the old one again and it doesn't work. So both injectors went out and are giving me troubles, could the one not working cause a bad idle rpm? (Sounds like it's turning 5,000 rpm with the pesky exhaust leak) -
Body and suspension lift
PathfinderProject1988 replied to Lukemann351's topic in 86.5-89 WD21 Pathfinders
That helps a lot! Thanks! -
Can you post a link to the lift you got? Thanks! Playing hell to find one for an 88 -
Idle problems
Brake light on the dash, and the air cleaner is on good except the wing nuts ontop have been miss placed and the the plastic "tube" that runs to the air filter housing is off, it kept getting in the way. -
88 pathy 2 door v6 throttle body, Rebuilt the throttle body, got a new injector, put it back together. She runs and won't idle cold or warm.. Replaced all the dry rotted vaccum line, Right now I'm having to do the brakes. The background on the pathy: It was my fathers and it needed new tires and shocks so instead of spending the money on it he let it sit. Till I got bored one day and decided to make her ride again. So far we have had to get new slave cylinder, master cylinder, vaccum lines, gas tank and fuel pump, oil change and soon brakes Any tips, tricks? Also the brake light stays on for some reason.
so much great info on suspension lift, workin on a pathy that sat for 10 years and got it going again today,, soon will be getting all kinds of goodies.. -
Good luck at a junk yard, nothing there is old enough, haven't found anything with a throttle body on it, which i need -
bringing an 88 pathy back to life
So after a few try's to get them clean they still keep spraying, is it time for new injectors? -
Unplugged them and they kept spraying now gonna pull them out and try to clean them up, thanks for the help -
My tbi injectors are stuck wide ass open and pissing all over the place...we turn the key to ON and it just straight starts spraying fuel and when i mean fuel like holy @!*% stand back. i flooded the motor please help us out and if you of reasons to why it would be doing this please respond. -
A few weeks ago a buddy and me started to fix up an 88 that had been sitting around 10 years. we have replaced all the vacuum lines (about 1,000 miles) and fuel lines, got a new gas tank, fuel pump, fuel filter and cleaned out the carburetor, did an oil change. new slave cylinder and master cylinder. we got it to start and drove it around the yard but now she just wont run or idle or anything. This weekend we are gonna re-build the carburetor, Anything we should check on that might be wrong? thanks
I ended up cancelling out the filter, i used heater hose and attached it to where the reed valves were and then cut off the mount for the bracket on the other side and put the heater hose to that. basically put heater hose where the filter was. -
They don't check anything for emissions in Florida ever -
has anyone just eliminated it before? and how did you do it? -
Does anyone know where i could buy a new one for my 88 pathy? old one rusted through the bottom
1988 Gas Tank. Rust issues
is it safe to put that pour15 stuff inside the gas tank? -
i did it with vinegar and threw nuts and bolts in, but some of it wont come out is it gonna give me problems in the end? -
Anyone know of a place to get one cheap or a cure to get rust out and keep it out? I've managed to get a bunch of the rust out but its impossible to get it all thanks!
