Everything posted by thorpe991
So I havent been on in a while since i gpt a new vehical but the other day i went to mud the pathy(all its good for since it wont pass smog) and i had no power steering had it when parked in december i have it a little but not much so where is the power steering fluid fill spot?
Mine blew the top house thing on the radiator and i forgot to say you have to unhook the fan shroud
Mine did the same i think but it's super easy you unhook the hoses and unbolt the 2 nuts on the top if yours is a r50
It makes right around 285hp but it does have a could air intake so it could be about 290hp So it just a matter of time befor it gets put up there haha
So this is what i ended up with a 2000 gmc Sierra step side z71 4.8 vortec 5 speed manual it has 2" of suspension lift and a 3" body lift and sits on 35s custom grill and soon to be custom headlights and tail lights super clean interior and it has 148xxx
So ... Yesterday i noticed a crack in my new glass :-( and i still have yet to get it inspected so i will be parking the pathy till next summer as i don't the have money to fix the window and i smelled burning oil back by the exhaust so i will not be on in a while im looking at a 06 xterra with 85000 miles or a 05 jeep wrangler with 75000 that are the same price so good luck to all here with your projects
Yep they work to and today my gas gauge came back to life think it could be a short in the actual cluster?
So yesterday my tach temp gauge and fuel gauge stopped working they move when i first turn the key on but thats it and i tore it apart to see if any thing looked broken or burnt and noticed that there is a wire that is loose from the coil/motor thing for the tach nothing else seams astray i looked in my Haynes manual and didn't find anything about a fuse for the gauge cluster oh the Speedo still works
So my light kicked off yesterday and i dropped another 100 rpms and better acceleration and but my rpms are still bouncing about 100 while cruising
Not that i know of (i dont have one but am looking into getting one) the point of a sfd is to correct cv angles and allow for bigger than 31" tires
Yeah havent made it there yet as its been below 20 the whole week here on ny
Swaped the battery from the camaro to the pathy Pathy batt 530 cold cranking amp Camaro batt 700 cold cranking amp
If you were to get the actual bumper support from.a face liffted pathy it might line up better and would use factory mounts other than on the sides
this is of the selftap and in that hole there you can see the 97 bumper being used as the bumper support some trimming i still have to do the selftap that is holding up the end of the fender
Some trimming to fit fenders and i just selftapped the sides to the fenders and i didnt have the bumper support so i used the old metal from the old bumper and more self tapers ill take more pics tonight
With my green led grill lights haha there hooked to my old running light wires
Had it read again and they said it is now just the evap solenoid sending a code so headed to pickapart tonarrow to see if i can get lucky
Maybe it was the gas cap idk but sel still haven't reset are ether one of those codes ones that have to be manually reset
Hey my local jy has a 300zx with the 3.0 in it is a 86 is this also a vg?
My sel hasent reset but since doing the o2 im running about 500 less rpms at all speeds my bouncing rpms at crusing have lessend ( it was jumping about 300-500 now is only jumping 100) Im going to drive it today and then tomarrow im taking it to see if it will pass inspection i also replaced the gas cap
Got the new bumper mounted up ill get pics tommarrow
So did they ever make a 99 - 04 r50 with the tire carrier? I dont mean in the is i mean every wheres because i seen a baby blue face lifted pathfinder with all correct flares bumpers markings and interior ( i creeped alil) with a tire carrior on the back and the licence plate holder was molded into the hatch off to the side
Well the fender isnt in perfect condition i had to cut the very bottom of it where it bolts to the body because the bolt was stripped and mine was busted off inside of the hole that it bolts into so i wasnt worried about it
