27
Everything posted by Rebelord
I've replaced both O ring for the oil cooler. Still seeping. Sent from my SM-G920V using Tapatalk
98 Pathfinder Idle's Up and Down when stopped
Rebelord replied to Mrelcocko's topic in General Forums
That is correct for the 3.3l. Idle re-learn is only for the 3.5 Sent from my SM-G920V using Tapatalk -
Bottoming out or over extending? Either way, with 3" of lift, you'll need longer rear shocks. For the fronts, your stuck with standard replacements. Because no one makes longer extending struts for the fronts. Edit: If the rear is still actually smacking the bump stops even after 3" spacers. Your springs are shot to hell and need replacing. You can find Moog replacements for cheap.
Loaded up when we went to Fish Eating Creek for a week. Need a bigger truck.... Sent from my SM-G920V using Tapatalk
I'd check the IAC. Go by the fsm procedures. Heck maybe the plug has some debris or corrosion from being open for 3 weeks. Could try cleaning it. Sent from my SM-G920V using Tapatalk -
I run Gabriel Ultra struts. Been good for me. But do ride a tad stiff when new. I run the Gabriel Ultra shocks on the rear also. But the Bilstiens would be better in the rear.
If yours are shot. But dont want to spend money on OEM ones. Heater hose put on the end coils works good too. To keep squeaks away.
There is actually a set of coil overs that work for the R50. For some kind of van in Japan. Uses the same front suspension setup. A guy on the forum a ways back had a set. I remember he had them up in the For Sale section. But they weren't exactly lift coils, I think they were more geared toward lowering. However, they do "exist".
Is there a Auto Hobby shop by you? They would have all those tools and rates should be about $20hr to rent a lift. Then just do it yourself. If not, have a friend help. Do the rear springs, take off struts. Take them with new struts and springs and mount to Pepboys. Have them assemble your new struts with new springs (have to re use upper spring perch) mount for you. Mine does that for about $20 each strut. Just make sure when they do, they clock the upper spring perch correctly.
If you want to do both but stay stock height. Gabriel has a complete unit. But makes for a easy drive way swap out. Sent from my SM-G920V using Tapatalk
2000 Pathy lift with front and rear coil Spacers only.
Rebelord replied to mickmutante's topic in 96-2004 R50 Pathfinders
Might need a second set for the front. I had to use two on each side. Perfect now. Sent from my SM-G920V using Tapatalk -
Rebelord replied to fleurys's topic in R50 FAQ's & Pinned Topics
Pathfinder front hubs are something like 104mm. Chevy's are 100mm. -
Yup, this dreaded code. Been reseting it off and on over the past year. Once cleared, sometimes will stay gone for a day, to weeks. Now, yes, I know the code and what it represents. Just that the cause, is where I'm at a cross road. So, my intake tube, does have some cracks in it, dont really notice them unless you move it in a way to "open" them. If they are leaking, un metered air can set off this code. I did call Rob out in Texas about the tubes, unfortunately I'd have to buy the whole intake system for replacements. Unlike the 3.3. where you can still buy the rubber parts solo. Secondly, I haven't changed the O2 sensor, but I may try that first. Thoughts? BTW, this one will be a major PITA to swap out. =( Thirdly, just say screw it and decide to replace the CAT and the O2 at the same time. Which, may as just do both sides, and call it a day for the next 150-200k miles. Anyone else have fun with this code to offer maybe a trick to not have to spend a ton of money?
You'll be fine with those spacers. I run ARB OME springs and those spacers also. Front CVs are at max angle, but otherwise fine. -
Sierra expeditions also. You can ask em if in the states and they will find out from ARB and let you know. Sent from my SM-G920V using Tapatalk
Cover King seat covers. Some balk at the price. But they are very good. Sent from my SM-G920V using Tapatalk
Ignition switch? My wife's key is worn. Can remove once started also when she shuts the truck off sometimes it's not all the way off so stuff stays on. Sent from my SM-G920V using Tapatalk
very minor trans/transfer case leak.
Rebelord replied to vg33deguy's topic in 96-2004 R50 Pathfinders
There's no gasket. FSM states use RTV to seal. Sent from my SM-G920V using Tapatalk -
I towed a 21.5ft camper trailer that weighed over 3500lbs. Hat to pull it loaded with full water tanks and grey/black water. Did have a load level bars. Towed with the 99 3.3l. Iron springs only in rear. Plus 4 people and loaded truck. Towed fine. But couldn't go much over 55mph. 12mpg after 500miles. Just install a transmission cooler. Get the large plate style. Sent from my SM-G920V using Tapatalk
Pic of said leak? Taking about where the transfer case meets the transmission? No real gasket there, just RTV. -
Frustrating code after rebuild P0011
Rebelord replied to aussie4wheeler's topic in 96-2004 R50 Pathfinders
Oil level? Low oil can cause it. Also have you changed your oil since the break in? Try running some 0W with half can of seafoam through. Break up any left over assembly lube. Sent from my SM-G920V using Tapatalk -
CV Joint Axle issues after lift 2 inches
Rebelord replied to thejazzid's topic in 96-2004 R50 Pathfinders
As said not all cv rebuilt ate equal. Either pick some oem from a junk yard and rebuild or buy and try. There are multiple threads on this exact subject. It seems most have ok time with Cardone. But some have only been ok with OEM. I just keep rebuilding my OEM Sent from my SM-G920V using Tapatalk -
Check your oil level. If you get low as some of our 3.5 will eat oil. The cam solenoids don't have enough oil pressure to adjust the cams as commanded by the ECU. If I don't pay attention and get low about a quart. I'll throw those codes also. Sent from my SM-G920V using Tapatalk
misfiring, but without a misfire trouble code?
Rebelord replied to NovaPath's topic in 96-2004 R50 Pathfinders
Sensitivity to plugs. Yes. Stick with NGK brand. If you run other brands, you tend to have misfires etc. Its just one of them things. Remember, if you get the cheap NGK which is fine, they dont last 100k like the IR OE ones. 25-30k is a good change point. Check your oil level too. If your oil level gets low, likes to create havoc. As the cam phase timing runs off oil pressure. So if your low on oil, less pressure cam shafts dont run what they are commanded to. Some funky idle and weird off throttle issues. -
I picked mine up from Amazon. http://www.amazon.com/BAFX-Products%C2%AE-Bluetooth-diagnostics-Android/dp/B005NLQAHS/ref=sr_1_1?ie=UTF8&qid=1450315763&sr=8-1&keywords=bluetooth+obd2 This is a slightly newer version. Mine is from early 2013 and finally dying. But for ~$22 cant beat it. Works with Torque no problems. Able to read all the sensors that our ECM will allow to be read from OBD2.
