Everything posted by enkrypt3d
'93 SE 4x4 - Refusing to start (sometimes)
enkrypt3d replied to deanpence's topic in 90-95 WD21 Pathfinders
yea I understand...just seems to be a pain to remove... and the loose key is annoying haha -
Ever since I swapped to royal purple 10w30, and the engine is cold, the engine makes more noise when I start it up... truck has 160k miles on it so I figured synthetic would help (and it normally does) but this time the engine just doesn't sound as happy.....
Mine has an alarm but I dont think its factory... not sure where to look to disable it? I'd like to keep the keyless entry system though.... Is it worth trying to replace the ignition switch? The key is pretty loose though but replacing it requires new keys that would be different from the doors... -
Scraping my 94. Anybody need any parts?
enkrypt3d replied to DantheMayun's topic in 90-95 WD21 Pathfinders
so all these interested ppl but the seller is MIA.......................................... helloo? -
http://www.amazon.com/gp/product/B0007QGT34/ref=oh_details_o09_s00_i00?ie=UTF8&psc=1 This is what I put in the rear diff... it didn't seem to change anything.... the issue was happening before the fluid change and is still there.
I'm trying to diagnose the same issues here too. I took it to autozone and unplugged each relay and the issue did not go away until I unplugged the big gray one on the drivers side. With the relay unplugged of course it did nothing. The autozone guy was nice enough to let me try a new one in the socket and the issue was still there. They tested the battery and it's 100%....so I guess I have to replace my ignition switch now? ugh..... really hoping to not have to replace the starter again. -
Project 95 Pathfinder Resurrection
enkrypt3d replied to pathybuilder's topic in 90-95 WD21 Pathfinders
any updates on this project? I'm considering rebuilding my H233 LSD and putting in an R200 in the front... -
Already changed the fluid with royal purple and it made no difference... Any drawbacks to having an LSD in the front? for drivablility on the street etc?
hows the dash? pics? driver's side door arm rest and seats? -
I have the H33B (not sure if that's the correct model) LSD for my pathy but it needs a rebuild..... tons of shuddering when making tight turns in forward & reverse. What should I do? rebuild it? Or ? Thanks Also is it worth putting the R200 LSD in the front? Any draw backs?
whew that makes it much easier for smog... my 95 nsx is obd 2 fml
Its hard to tell how all these header parts fit together honestly.... is the pathfinder obd 1 or 2?
Ok so i got the headers..... and noticed that the bung for the o2 sensor is hanging off of only one of the runners. which means the ECU will only be able to monitor the o2 from one cylinder. I've seen this cause problems before on my NSX (which is OBD II)... would this cause a problem for the 95 pathy? is it OBD II or I?
Xterra roof rack install on my 91 pathfinder
enkrypt3d replied to snowboard419's topic in 90-95 WD21 Pathfinders
Man this looks badass! although I have to worry about clearance issues going into parking garages downtown.... right now the FM antenna slaps on everything in sight so I'm unsure this would fit as much as I love the look. -
Well im hoping this exhaust isn't too harsh or annoying and just gives it some more torque... the new MAF sensor didn't really seem to make much difference though. The timing was done with the new distributor cap / rotor / plugs and wires...... after all that was done it was running very strong and it just recently started sputtering and has less power.
http://www.4wheelparts.com/Tires/31x10-50R15-Mud-Terrain-T-A-KM2.aspx?t_c=13&t_s=156&t_pt=100697&t_pn=BFG00606 http://www.4wheelparts.com/Wheels/Classic-III-15X8-with-6-on-5-5-Bolt-Pattern-Black.aspx?t_c=11&t_s=210&t_pt=100039&t_pn=M%2fT90000001749 These are the tires & rims I have FYI... I need to order a 5th one for a spare.
Now I just gotta figure out how to get the o2 sensor off without busting up my knuckles.....
yea timing belt and valve adjustment done already.. went out to replace the MAF since I had the parts already and that clip went flying just as you said adam lol luckily it bounced off the hood and onto the distributor cap... u guys think i should unplug the battery to reset the ECU after replacing the MAF?
Fan is not loud after it warms up for a few mins... and yes tires are 31x10.5 on 15x8 rims... only slightly heavier than stock.
Thanks Alkorahil! I think I found the part but it's out of stock. Hoping they are able to ship it out soon!
If you're not willing to contribute constructively to this thread then what are you doing posting here? My truck *should* be able to haul 4 people and not have to floor it... isn't this what forums are for to exchange helpful tips? Driving in 4L everywhere off road doesn't make sense at all so by that token that is incorrect. These roads allowed me to drive up to 25mph in 4H and it was fine. The issue I'm talking about is not being able to climb long hills on the freeway in 2H in OD. The only option was to turn off OD and floor it. So we're talking about 2 separate things here. Anyway I think that replacing the O2 sensor, MAF & PCV will help.....
Is it worth having the ECU tuned after the new goodies are put on?
Ordered new MAF harness, ignition relay and hose thanks! Hoping these parts can be sourced... so hard to find this stuff!
Yea if I could find the part number to the hose that connects to the PCV... it's dry rotted and it snapped when I tried to remove it... Also I have no idea how to remove the MAF plug.....?
In the video I'm in first gear. Of course I'm not flooring it as I'm not trying to get stuck out there by myself several hours into the middle of the desert. I now drive with power mode on and it drives much better. Next time its in the shop I'm getting the PCV, MAF & o2 sensors replaced as well as the headers & exhaust. I'll have to check the cats to make sure what diameter it is...
