Manik
Everything posted by Manik
  1. Chop shop Sent from my LG-H700 using Tapatalk
  2. My 95 has 6 marks and unfortunately my laptop was at work, it had tge FSM on it. I found kind of a definition on YouTube, but, it was all I had, so, I went with it. The timing was set on the very last mark on the right on the pulley, so, I knew it was way off. I set it at about 10*, going to give itnone last shot at emmisions later today. [emoji106] Sent from my LG-H700 using Tapatalk
  3. Sheet cake Sent from my LG-H700 using Tapatalk
  4. Good news and bad news.. It finally passed on the high speed ASM test, it still failed the low speed, but, got a helluva lot closer to passing. I replaced the EGR valve and ran testing on ethanol free fuel. NOx dropped be 1000 points and HC has been just above the FAIL line at this point. The guy at the station suggested retarding the timing about 2-3 degrees. I checked the timing and it settled on the first mark on the pulley. I changed it to probably 20* I'm guessing. Runs great, but, would still like the definition of the marks. You know, 0,5,10,15 degrees and so on. Thanks again y'all. Sent from my LG-H700 using Tapatalk
  5. Table top Sent from my LG-H700 using Tapatalk
  6. Round stock Sent from my LG-H700 using Tapatalk
  7. Dummy round Sent from my LG-H700 using Tapatalk
  8. Crash test Sent from my LG-H700 using Tapatalk
  9. Job site Sent from my LG-H700 using Tapatalk
  10. Gun nut Sent from my LG-H700 using Tapatalk
  11. Gun safe Sent from my LG-H700 using Tapatalk
  12. Safe space... Sent from my LG-H700 using Tapatalk
  13. Office space Sent from my LG-H700 using Tapatalk
  14. Electric guitar Sent from my LG-H700 using Tapatalk
  15. Striped bass Sent from my LG-H700 using Tapatalk
  16. Bass fishing Sent from my LG-H700 using Tapatalk
  17. Trout fly Sent from my LG-H700 using Tapatalk
  18. Gulf stream Sent from my LG-H700 using Tapatalk
  19. Off shore Sent from my LG-H700 using Tapatalk
  20. Cue tip Sent from my LG-H700 using Tapatalk
  21. Figure eight Sent from my LG-H700 using Tapatalk
  22. Yea, where I have to get it inspected is a 35 minute drive from my house. Both times I went to get it inspected, it sat for 2-3 hrs until the guy showed up, so, this weekend it wont get shut off until the inspection gets done! Sent from my LG-H700 using Tapatalk
  23. Yes, mine has the BPT, seems a helluva lot like overkill. I had already ordered an EGR valve for it, but, it was a standard EGR that does not have the BPT port, I did install it last night and test drove it and damned if it didn't seem to wake up the little VG. One thing that I am going to do is fill up with ethanol free fuel prior to the next emissions test. One thing that I noticed last night was, this sounds very weird, after the test drive last night, the exhaust was actually hot, as compared to the last test, I could not smell it and the exhaust felt, not cold, but not as hot as I think it should have been and I could not smell it at all. This time I could feel the heat and smell the exhaust as I should be able to. Weird I know, but, I think this will do it. Another thing that I realized, when they did the emissions test, it had sat for nearly 3 hours, so, dead cold and had only been run for 10 minutes max prior to testing. With headers, I found that it takes much longer for the CAT to get hot and do its job. We will see what happens this weekend. Oh yeah, fixed a leak at the header to EGR tube connection, I think it was sucking air and cooling the exhaust, dont know for sure, but, just my theory.
  24. Pizza box Sent from my LG-H700 using Tapatalk
  25. Box tops Sent from my LG-H700 using Tapatalk
