AzZo
AzZo last won the day on July 21 2013
AzZo had the most liked content!
About AzZo
- Birthday 01/01/1914
1995 se4wd
Skilled/Experienced Mechanic
Choose
Choose
1995
Gender
Not Telling
mesa,az.
Country
3,924 profile views
AzZo's Achievements
NPORA Old-Timer (5/5)
22
I like the idea of just attaching to the valve cover screws.I am having the same issue's on my 95.
Ok I understand B and a hardbody it does need to be what I call double grounded to frame and body for electrical to be happy.I really appreciate all the imput as I am not as good with electric's.Thanks again,Jack.
Wow thanks man well I can do the heavy gauge wire with the I loops.But can the neg. battery be just one long one or does it have to be split like it is and bolted to the wheel well slash / fender I caused this my self I went to unbolt it and even with pb blaster it snapped off.I have a small bolt,washer and nut on it now but wondering if it is doing the same job as stock set up.Am I over thinking this? Jack.
Hey guys I recently took off heat shields to look at the condition of my manifold bolts and there are these ground wires but not round wires they are flat and connect to the heat shield bolts both of which broke off upon loosening.I can live without the heat shields it really doesnt get that hot but how important are those grounds one on both side's of motor.And whats with the black negative battery cable its two pieces that are split with a portion bolted to the wheel well cause that bolt is also broken off.Can I buy one long black NEG. cable or is that separation a must have type of deal??? I know so many questions I really feel dumb at this point.But any and all response's welcome.
Oh heck yes that guy had the right idea impressive for a jeep owner.I like your rough draft good luck with it.jack in IOWA
Yeah if it feels right do it I wouldn't leave my pathy behind always a way around paperwork.I'm sure you will get it sorted out like dave said check with dmv and or insurance.
Good day mate welcome to NPORA hows things going in the land down under.Do you like PERTH? Iv'e always wanted to visit Australia its on my bucket list my travel agent says it takes like 19 hours to fly there.
Yea I have seen everything from steel braided line to stainless steel which never rust's but whose got that kind of money I sure dont .Flex hose sounds best I had to replace my fords a few years back.
Yeah had me going for a second I have the same problem so much I want to improve on mine.Well a little at a time I try to do one thing a month.
Hey anybody I have a question and I hope it does not sound to stupid.But remember though I have owned many cars and trucks in my lifetime this is my first 4x4.Here goes should I install a steering damper my 1995 LE pathfinder did not come with one but I am seeing a damper in the Chilton's Manual.I dont off road a lot mostly street and highway.What's the verdict folk's?
Ah yes opinions are like { you know what } everybody has one.HA,HA,HA, I dont care, I dont care I dont care....ect....ect....
I dont practice religion anymore after I served I kind of lost my faith and I had enough shoved down my throat attending parochial school.Tis better to reign in hell than to serve in heaven.Milton, paradise lost.I only wear a cross around my neck cause One it's solid gold and two my MOM's gave it to me.
Wow thats really Weird.I myself being IRISH and a roman catholic always wear a gold crucifix around my neck.And when younger never was without my SAINT CHRISTOPHER medal.I think the state should be neutral.I still remember in grade school when we recited the pledge of allegiance.Then the powers that be decided ONE NATION UNDER GOD was just to religious so they banned it in public schools.So my parents enrolled me in yep you guessed it CATHOLIC SCHOOL. jOHN JOSEPH AZZO I have 4 older brothers and a sister too mark, peter,luke,michael,and of course my sister theresa.Yes my parents named us from a bible.At least I got john the baptist.
I also own a 95 pathy the bolts on the cover under rear carpet are 10mm spray with pd blaster and removal should be easy.Same with the bolts holding gas tank and gas tank cover lots of pb blaster or some penetrant I to broke bolts off removing mine.Pathfinders have a welded seam that with time tends to spring a pin hole leak.Mine was on passenger side underside of gas tank.I first tried JB weld but it didnt take what worked was the two part gas tank epoxy sealer.Two years and still going strong and leak free.But also new tanks are around $100.00 bucks which ever you feel more comfortable with some people are funny about gasoline tanks.Good luck and keep us posted.
Man I like that totally rare.
