Motofish last won the day on November 15 2022
Motofish had the most liked content!
About Motofish
- Birthday 04/28/1981
'93 SE 4x4 5spd stock awesome VG33 swap In Progress!
30-35
1993
Gender
Free 'Merica (Apopka, FL)
Country
Motofish's Achievements
NPORA Regular (2/5)
Wow, sorry to hear and see that... I'd definitely try the "fishing through the sparkplug hole" idea first. Maybe a simple magnet with a flexible shaft would find them? They look pretty small. At this point since you had it towed pretty quickly afterward maybe there isnt much damage to the cylinders? Since you know which ones are missing you should know which cylinders to search in right? Say a prayer and hope for the best!
Awesome thread, I love all this technically detailed knowledge! Thank you guys! Wanted to respond here so i can follow this thread, but more importantly, to caution against relying too much on the small visual details in the FSM... Im finishing a VG33 swap into my '93 wd21 and have been referencing both the FSM's to compare a lot of the pages between vg30 and vg33, and have noticed a lot of diagram sharing where its not correct (nothing terrible, just things like a diagram showing a V belt pulley where the '33 uses serpentine, or the "fresh air inlet tube" on em-6 of either vg30/33 fsms, not entirely similar in reality, but drawn the same in the book) Im not saying that is the case here, but just saying to not fully trust those drawings 100%... They might have reused a detail that they didnt feel it was important to re-draw. Edited to add: Sorry hawairish, i must not have fully read your post, I said nearly the same thing you already had, just not as concisely...
Removing (replacing) rear axle and/or differential (LSD)
Motofish replied to microfiz's topic in 90-95 WD21 Pathfinders
If one was replacing the entire thing anyway, is there anything that would drop right in, as a j/y upgrade? Like a dana (something with more aftermarket support), or something that comes with a factory locker? -
Wow! Bookmarked! That was a great article! Good find! It seems like that site has good info on other topics as well, Thanks for the link! I like the wiring diagram they threw up there. Very simple!
I have had too many of those types of electronics (T-max) fail on me. The buttons get old and crack/corrode and its just not worth it for me either. Thats great info on the Blue Sea switch, sounds pretty capable! I think that is the direction id like to go as well (as if i need another project right now...lol). If you dont mind me asking, where do you source that kind of plastic from? It seems like there would be tons of uses for something like that. Overall, sounds like a good plan! Im looking forward to seeing the install (if you decide to post it up). I would tackle this one soon... But i think it would work better with an engine in the truck... Lol. (Partway through an unnecessarily lengthy vg33 swap). But i hope to see yours soon!
Agreed, since in this case the ACR should be isolating the "full" battery anyway during charging. I think other systems would only add levels of automation and perhaps some type of convenience features. But you have boiled it down to the essential elements, as i see it, as well. Yes, i think that would cover the necessities, other than adding your own voltage readouts, which i think you said you already have (at least for your current setup). I like the idea of the blue sea systems rotary knob vs tmax's style of buttons from a durability standpoint. Also, a quality electrical component designed for marine environments should be ideal for our purposes due to superior corrosion resistance, i would think. What do you think about vibration? Would that be more of a concern for 4wd than it would be for marine? Maybe that answer would depend more on what type of wheeling one does with their rig... Also is dust a concern? Im still vacuuming dust out of my pathfinder and i havent wheeled in the desert for over a year! Lol. (Used to live in SoCal) I think you have a good plan for your system, its protected from overcharging, your starting battery is protected from excessive draining and recharging (isolated), your selector is simple and easy to manipulate, as well as durable from a corrosion resistance standpoint...Are you planning to put them both under the hood?
So if you will be running everything but the starter off of your secondary (larger) battery, and only using the smaller for starting, that would neccesitate having battery 2 connected to the alternator most of the time and battery 1 only long enough to replenish cranking losses? So in your setup maybe a standard battery would be better? I guess the reason i was planning on a deep cycle for my secondary battery is because ive heard that frequently draining to low level and recharging a normal lead acid battery will result in an early death for the standard battery. (Im thinking fridge, lights, etc while camping, engine off) I figure with the light duty it would perform in the backup role, a deep cycle should last a very long time... If thats the case, i would think it would be well worth the initial investment for a potential 10-15 year battery (2-3x lead acid lifespan). Im still doing research, though, and have a lot to learn about batteries, and things. But maybe someone who is more knowledgeable can jump in and drop some knowledge?
I have been planning nearly the same thing. It seems like this should be about ideal as far as a switch goes: http://www.amazon.com/Blue-Sea-Systems-Selector-Battery/dp/B000K2MCR2/ref=sr_1_1?ie=UTF8&qid=1438047183&sr=8-1&keywords=Marine+battery+switch Im a fan of the k.i.s.s. principle. Are you currently running a deep cycle battery? That would be the best choice for frequent current drain applications with the engine off, as far as i know... Something like this: http://www.amazon.com/Optima-Batteries-8014-045-YellowTop-Purpose/dp/B000MSBUA4/ref=sr_1_1?s=automotive&ie=UTF8&qid=1438047506&vehicle=1993-67-893-49--9-12-8-5591-1727-4-2-1873-18-3-0&sr=1-1&ymm=1993%3Anissan%3Apathfinder&keywords=optima+yellow+top Im planning on this being the second battery and then getting another to be the main battery when my current standard die hard, dies... Finally, you would need a way to moniter each system... Thats where im hanging up a bit... How to monitor the actual battery level while it is charging. A voltage readout will only be accurate while the battery is not charging, otherwise if its tied to the alternator it would read system voltage correct? Maybe that is where the T-max actually saves time and money?
Pretty ugly clutch noise when I touch it... Ideas? (bonus pics too!)
Motofish replied to taylorhayis's topic in The Garage
This is BRILLIANT! Im so going to do this thanks for sharing! Is it wired to 12v, or does it contain its own battery? Three of my favorite things! Though, for me "babes" = my wife 😀 I honestly did not know this! Im no master mechanic, but if youre going to go through the effort to pull the trans (or even move it back a bit), id recommend changing everything back there: throwout bearing, clutch, pilot bushing, rear main seal, maybe even front trans seal... If for no other reason than to ensure you dont have to go back and do the same job for anything that could have easily been done at the most convenient time. The various parts are not that expensive. Piece of mind is priceless... If youre paying to have it done, then its most cost effective to bundle the jobs as most labor is related to accessing the area. Thats just my .02 cents, and what i did in my case. Goodluck, hope it goes smoooooth! -
Maybe its an opportunity for another first... Im thinking semi truck style, roof mounted pull cable horn! 😀 http://www.ebay.com/itm/Air-Horn-Big-Rig-Pull-Valve-Heavy-Duty-Trucks-Grover-Valve-Lanyard-Cable-/281453224519?hash=item4187eb6247&vxp=mtr
Woohoo! Glad you got it worked out! Now then... Whats next on the mod list? Gotta keep this build thread going right? 😬
Those have to be the biggest visors ive ever seen! Id agree, not my style, but interesting! CDN, your truck is looking really good! Ive been following the thread, although i dont have an R50, ive found this thread to be quite captivating... not sure why, maybe its the fabrication. Anyway, kudos on your rig!
Stay away from the stop leak stuff. It only ever made my systems fail after a short time. If you have a leak, replace the oring. Otherwise id stick with recharging it with plain old freon. I had an issue with my '93 where it was freezing up due to moisture in the system. I took it to pep boys and had them evac and refill the system for like $50. Took care of the problem. If youre going to open it up and replace the orings, id just have the system purged and filled afterwards.
Former land rover guy converted!
Motofish replied to aussie4wheeler's topic in New People Start Here!
Sounds like fun! Welcome to NPORA! -
Personally, I chose to give my good friend a newer more powerful heart... 😷 This! Its worth it! Plan it out, whatever you decide. Is it a daily driver? How long can you park it for while working on it? And what are your longterm goals for it (street/wheeler/combination)? In my case, I chose to do a simple vg33e swap (currently underway) because of increased displacement and availability of engines/parts (its also a relatively easy and inexpensive swap... "relatively"). But your reasons may differ for what you are intending for your pathy, and depending on funds/time/facilities... I guess the question is what is most important to you? There are a lot of V8 swap threads, vg33 swap threads, and a few vg34 build threads. My advice (for what its worth) is that if you are looking to do any kind of turbo vg, might as well go for a vg33et... I read it somewhere that "anything you can do to a vg30, you can do to a vg33" i forget where i read that, but it's interesting. Im sure someone who knows a lot more about vg's, turbos, and cam swaps (etc.) as well as engines in general can tell you a lot more. But you have a lot of options!
