Everything posted by Heloflyboy
88 Pathy 3 link front. 63" chevy rear
Heloflyboy replied to BIGFINDERMAN's topic in Solid Axle Swaps, Hardcore Custom Fab
Looks great. I cant wait to see how it does on the trail. -
Thanks everyone. I will send you pics Precise1
Been out of town for a month, and still not done?
OK what happened?
Towing Questions or maybe Replace the Pathy?
Heloflyboy replied to TahoeRunner's topic in 90-95 WD21 Pathfinders
I would not recommend it. I had a jayco baja with the large platform. The pathfinder would tow it fine until I got into the mountains, then it was a slug. Being you live in Reno area I would say don't do it. Remember weights listed are usually not wet. -
Looks good.
All right here you go Heloflyboy
I like the TX10 idea because it stays Nissan. I don't really care for other ones. If anything a toyota case adapter would be best. I think North West Fab already makes a dana 300 adapter to TX10. In my experience once you double it and put 4.1 gears in transfer case you start finding the other weak links. Good luck
I did not notice, but are they a C or an E rated tire. That will make a difference.
Keep me in the loop. Clockable would be a big plus, but I do not know if it matters since the engine sits further to one side then other. That might be asking to much.
I have this taking up space in my garage. I do not want to ship it but would give you a good deal. It needs new bushings, but I think I have a set of those I do not have shocks . It is a 4x4 parts kit with rear springs,idler arm brace, heavy duty sway away torsion bars and cal mini drop track bar bracket . I was thinking $250. I live in mountain house 95391 probably 5 or 6 hours from you if your interested.
Where do you live?
Welcome. Let me know if you need a lift I have one sitting in the garage.
Welcome. I will have to get in touch with you in October when I will be in Wales. I would like to go wheeling when I'm there. I usually have a range rover to drive. Cheers
So i'm driving to Oakland, I need some tips, and ideas.
Heloflyboy replied to ferrariowner123's topic in Off-Topic
Why drive 13 hrs to get car painted? Is this guy that good? By the time you factor in food rental car and bars it ends up being a very expensive paint job. -
I use Monroe's or kyb's on my stock vehicle's. I dislike rancho I just threw away a set of 9000's , second set they are garbage. Rancho in my opinion is crap. I have a set of bilstein's now and are a lot better.
It all depends on how much work you want to do. If you use a front full size axle you should hit the wreaking yard for full size rear also. Will it be legal where you live? Full size axles stick out pretty far. Are you making a rock crawler, or something you can still drive every day? Full size axles are not practical for every day use. I only say this because I have done it to a jeep. I would say the easiest thing to do is find the wagoneer axle. If I were to do another swap I would go that way. The rear factory setup will work to a point(with larger springs and dropped track bar), but you will find it's limitions if it is pushed to hard. Good Luck
Welcome, I used to live in Tahoe Keys, had to move back to Bay Area for work. (real job) Just starting to look for another vacation home up there.
Real job Union Electrician goof off job Helicopter pilot.
Thanks everyone.
Welcome. Looks good.
No. I refused to bolt through my cab which is the only real way to keep it all tied together. It has worked very well on rocks not slamming against truck. I slammed against a rock very hard on the drivers side and the cage moved enough to dent the bottom of my cab. I figured it was a small price to pay for what could of happened without the cage. My family and I were in a very bad crash in my old 4runner on the way back from tahoe by a guy who crossed the HWY. He hit me in my door at what he told police was about 90mph we had a full cage and rock rails, my wife is now permenantly handicapped because her leg went out the window, but she is still alive.(don't let people rest there legs on dash). Anyway I don't care if the exo hits the cab as long as we all walk away from a roll over of any type. Probably to much info. haha
I think I used about 100' I wasted about 20' trying to figure out how to do main bar that runs from just behind front wheel to rear hoop in one piece . I was trying to find a good way to follow the roof line. It was a little difficult. Practice with your bender a little, figure out the bend radius and center of bend if it is not marked on your bender shoe already . Finding the center of the bend helped me out to follow the lines I wanted. I also used blue masking tape to get a general idea of what I wanted to do. I used a Lowbuck bender, it works well but is time consuming. I am a electrcian so I bend conduit regularly which makes it a lot easier. Thanks on the center bar.
