Nefarious
19
Get ready for my new endeavor - MRJIM II
Nefarious replied to MrJim's topic in 86.5-89 WD21 Pathfinders
Do you mind if I ask where u got the headlight and taillight covers ? -
might as well do it all at once, save $ on alignment that way !
moog problem solver inner tie rods for 2wd swap? If so, those things are beast! We installed them on my wife's rig and they are still solid as the day we put them in 20 000 km later and many offroad adventures
A ka24e wouldn't be the choice I would make. I would much rather swap in a ka24de and add a t3 sized turbo to the deal. Then you have the superior fuel economy and torque of the double overhead cam engine and intake manifold butterflies. A ka24det with around 8-10 psi of boost pressure will yield around 250 hp to the wheels of a rwd car. So maybe 240 to the wheels on a truck and will most likely get a few mpg better than the vg30e. Then again you would be downgrading your transmission to make the swap happen and your peak torque would be at 4400 rpm instead of 3800 rpm but that could be adjusted with driving style. In my personal opinion the ka24de is the most reliable engine that I've ever owned and that alone would make me consider the swap if I didn't already have a vg33e in place!
I would personally look into either swapping to a vq35de using a VQ to VG bellhousing adapter; or, build a vg34e with higher compression. You can get over 220 hp and a lot more torque out of a vg33e bored over to 3.4 using used vh45de pistons. It also bumps the compression up from 9:1 to closer to 10:1 (I think it ends up around 9.8 or 9.9), yet will still run on 87 octane fuel. It gets significantly better fuel economy than a factory VG as well due to the bump in compression (and the engine really not needing to work very hard to push the pathy). I currently run a vg33e in my 92 pathy, but I'm most likely going the vg34e route myself once I get the parts together and then likely adding a small mid mounted turbo setup to sweeten the deal. Low boost 6-7 psi setup on a 9.8:1 vg34e would easilly break the 300 whp mark and be just a blast to drive with instant turbo response and would still be incredibly reliable. Factory ecu and wiring can be used with this setup as well with no issues as the stock ecu can be tuned to support the changes. my vg33e donor cost me 200$ and I would expect to pay around 800-1000$ for the used parts and machine work to put the vg34e together properly with a full rebuild. 1000-1200$ is not a high price to pay for a basically brand new over bored high compression engine that will literally drop right in with very few modifications. -
You posted about a vq30dek. A vq30de needs just as much work as a vq35de to fit. I'm confused? -
If you are going vq then I would suggest dropping in the 3.5 from a 350z or pathfinder. It has a lot more use able low end torque which would be more beneficial for a truck and the same amount of work and likely price. They are great engines although maybe just slightly less reliable than the vg. Great power though and light as they are all aluminum. I'm pretty sure there are vq - vg bellhousing adapters available. -
The bushings just press in by hand once lubricated but I had to press the sleeves on. I just used the big fat bushing washer that holds the bushing in place and the end of the spindle nut and an electric impact to drive the sleeve on. Then once the sleeve bites into the inner spindle washer (it's serrated on the ends) u can remove the bushing washer and spindle nut and assemble it all by hand from there. No extra tools needed I just used the hardware that was on the spindle already to press the sleeves on. to remove the factory bushing sleeves I used a razor knife to cut away a section of rubber from the sleeve and the used an angle grinder and a cut off disc to CAREFULLY slice the sleeve from end to end (being careful not to cut into the actual spindle material). I had to grind away the inner corner were it meets up against the fatter part of the spindle to get it all the way through. Once it's sliced down the length of the sleeve, it should slide off pretty easy with a pair of channel locks twisting and pulling at the same time.
It's okay I got a 20$ gift certificate for my next summit purchase so I consider that close enough to 180! Lol you will really enjoy them though! The bushing fitment is WAY better than the energy suspension or prothane equivalents too. The sleeves actually press onto the spindles, they don't just slip on. The bushings are the correct length and require np trimming, plus the bushings have molded in grease channels to actually maintain lubrication using the zerk fittings. So glad I went with them
Obx headers have no fitment issues on a non body lifted truck. We just put them into my girlfriends pathy. They fit great.
I just installed a set of them. They literally made my truck ride better than I thought a pathfinder could ride! So smooth up front now I don't even feel minor road imperfections anymore. Feels a lot more like a full size truck the way it rides now. Very stable and very little disruption of the front end on the broken down roads where I live. You will like them I think! I got mine for 200$ on summit
Phew got the superlift ucas in. Such a pain getting the old spindles out and the old bushings and sleeves off but got it all done and wow does it drive nice now. I hardly even feel bumps or potholes on the road now. Feels like a full size truck with how stable it is. I am surprised how much more shock absorption the truck has from just the ucas and new bushings. Very happy with the investment.
Got my npora stickers from fleurys and also received my superlift ucas from summit. They shipped me the black powder coated ones (they look to be just rough country version which I was very happy to see, I love powder coat! ) Will be a fun weekend. Can't wait to get them in. My front ifs will be fully upgraded after this. superlift ucas, trailmaster 4" lift, full poly bushes all around!
Upper control arm thread repair failed...Now what?
Nefarious replied to dthemiley's topic in The Garage
M14 x 1.5 Helicoil. Easy peazy -
Nunya! Sell me your tail light covers if you are selling the rig ! Me want so bad ! Lol
No offense but you are crazy! 5 speed all the way; plus you literally just spewed a list of all the reasons why the 5 speed is better....easy choice in my honest opinion. The auto will only last so much longer...keep the one that will keep on keeping on!
Autopartsway.ca is actually a decent place to get a lot of parts. Free shipping on order over X amount is nice too and hard to find in canada.
Welcome to npora. Where abouts in b.c. are you located? Our pathy family lives on vancouver island!
Wd21 chassis with an r50 power plant, then you have the best of both worlds. My 93 is converted to a full r50 engine / accessories setup. Soon I'll be installing an r50 manual transmission to replace my tired old auto as well. The obx headers fit great. I've installed them in both a body lifted and non body lifted truck and the only difference was that the non body lifted truck needs the front driveshaft disconnected from the front diff and dropped down a bit. Literally took an extra 5 mins. There's also a little tab of metal that hangs off the frame on the passenger side that has to be cut off. I have no idea what it's for as both my 93 xe auto and my girlfriends 93 se manual had nothing attached to it. It just kind of sticks out there for no reason so we cut them off and that was the only mod needed. Very simple as it's a tiny bracket. the header fitment is great BUT it does require a custom y pipe to be made since they are long collectors and pass much further down the truck. The crossover pipe sits right near the transmission crossmember after the install. Sound and performance are great and we have had no quality issues. Mine are about 5 or 6 years old now and are still great
Installed an oil pressure gauge, and new combo pressure sensor/low pressure switch in the girls pathy.
But drums suck sigh. All vehicles should have 4 wheel discs!
The auto transmission started making a much more pronounced sound. Still drives fine, but makes quite a whining/whirring noise now in direct relation to the rpm / shifts. I'll add some Lucas trans fix for now, but I think the time has finally come to pull it off the road and convert to manual transmission. Have the trans and all associated parts sitting in the back but have really been lacking the motivation to get started. Especially since it's been winter. Pics to follow....
You won't know if the wires are working fine or not, unless they are really bad. You can test your ignition wires as per fsm. There is a spec in there. I don't remember exactly but it was around 1 or 2 K ohm per foot of length. It's in there somewhere
Finally got around to replacing the rear right tail/brake light receptacle. The tail light contact was worn out to the point of not working. Used solder and heat shrink to attach the one from my parts truck. Gotta love free fixes!
Obx headers are nice too. Have them on both pathys
