UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
ahardb0dy
  1. What ever engine has the clear tubing
  2. I would suggest getting rid of that clear tubing, possibly the vacuum is sucking it closed, you need to be using vacuum lines.
  3. I may have the cylinder case, will look little later, If I have it I can also rekey the lock to match yours.
  4. Found out last night, that the photo hosting site I use, Tinypic is shutting down, so I'm sure any and all pics I have posted will be disappearing. I'm going to save all the pics before it shuts down, I should have most if not all of them but want to save them just in case I don't.
  5. Just a heads up, I just bought a used column cover from a member on another forum and went to install it and came across a problem, not his fault, I never even knew there was a difference in the top covers, this probably wouldn't be an issue on the Pathfinder a most probably came with tilt steering, just wanted to share what I found. pic below is the stock cover from my 93, non tilt that I modified to fit the tilt column, you can see the opening for the ignition cylinder is towards the rear. New/used tilt column cover from a 90 Pathfinder, you can see the opening for the ignition cylinder is towards the front: I also noticed the bottom cover from the 90 Pathfinder is not as deep as the one from my 93, but the bottom cover would have worked, I just had to move all the wires to the right side
  6. The little pins are removed by drilling a small hole next to each pin, than prying the pin out with a scribe tool or similar tool
  7. My former 87 Hardbody never passed emission tests on it's own, with full emissions, cat and everything. I heard way back, not sure if it was true that Nissan rushed the VG30i into production and is why they had emission problems ??
  8. Compression/strut rods are dealer or junkyard only, Torsion bars I would recommend Sway A Way
  9. I worked in a 4x4 shop back in the best times for the Nissan trucks, 87 -90 ish, We installed many visors and all were made by Lund. Not saying there wasn't another company out there but I do not recall one off hand. There was a company that made them out of metal that were shaped differently than the Lund visor. I have a very old Jobber price book from one of the warehouse's who we got our parts from, I'll look through it and see if I can find another company.
  10. welcome I'm from Long Island, now living in Florida
  11. Does the AC clutch engage when you turn the AC on? May just be low on freon.
  12. I always recommend OSC radiators from Rockauto, they seem to be a good part
  13. Anyone know if a 4x4 Xterra trans can be used in a 2wd Xterra? Are they the same other than the tail shaft part? Thanks
  14. Non matching bottom, my bottom has a textured finish, the new ones are now high gloss, got the bottom for x-mas couple years ago: Original Craftsman box on the other side:
  15. My wife bought this for me today, late X-mas present, had to raise the shelf above it so the lid would open. after 2 coats of wax ! have to keep it looking good. LOL front view, nice and shiny !:
  16. Very nice step by step with the pictures ! I guess you have a body lift as the upper radiator brackets are upside down, did the same on my former 87 Hardbody with the body lift. A member on Infamous forum is swapping a VG33 into his Hardbody and discovered most of the JDM VG33's that are for sale have the alternator on the pass. side, he wanted to keep his on the drivers side, where it is on the VG30, but he found the oil filter bracket was too thick and it would not allow the alternator to clear , so he replaced the oil filter mount with one from a frontier, it is thinner and allows the alternator to bolt up and clear. A tip when removing the hood and getting it to re align is to drill a hole through the mount into the hood on each mount, than when reinstalling use a drill bit to line up the hole in the mount into the hole in the hood, once the drill bit is through both holes you know it is in the same location it was before being removed.
  17. Merry Christmas everyone !
  18. He said he figured it out and it no longer has a misfire. He said he pulled the TB and the gasket was all tore up
  19. he said he doesn't remember what the old plug looked like. He also posted a video of doing the compression test on #5 cylinder. I told him to get a new gauge because there is no way the reading he is getting is correct, he is showing 210 PSI, The service manual shows a new engine should be at 173 PSI.
  20. he said he pulled the valve cover today and everything is moving the way it should.
  21. Weird that the plug has spark when pulled and held next to the engine but doesn't effect the idle when the plug wire is removed from the plug while running
  22. I don't know if he checked for codes, it runs, but runs rough, he said it was backfiring on deceleration but than adjusted the timing and that stopped, His mechanic was saying it might be a stuck intake valve More info, engine has about 225K miles, has good power and doesn't burn oil. He said when he shuts it off it runs for a few seconds (dieseling??)
  23. Trying to help someone on another forum. He has a Hardbody with the VG30I (88), seems like it has a misfire on number 5 cylinder. He has replaced the plugs, wires, cap and rotor, the number 5 plug has spark when it is removed and placed near the engine. Engine has good compression and timing is correct. When he removes the number 5 wire while running the RPM's do not change. Any thoughts on this? Thanks
