23
Everything posted by silverton
Met Mister510 today, cool guy! Think we saw beavis but not 100% as we tried to flag 'em down but we were ignored. Met another guy with a green 4 door, more for show than for offroading though, it was super clean. So, in all saw 5 pathies including my own.
the local pull-a-parts here are 18+ and they make you sign and pay a dollar to enter.
baha, shoeleather express. that's funny.
my broken ones part number is 0 305 555 002
That's awesome, you both work within 5 minutes of my house.
Very nice!
I work retail too, thankfully we get our schedules 1-2 weeks in advance. So right now, I know what my schedule is up to april 10th, it's pretty nice for being able to plan stuff
I think it's a standard 2-3 gallons are left in the tank when the light comes on in most vehicles. But really, I wouldn't put 100% faith into the light, as it comes on/off depending on where the the fuel gauge needle is. so.... if your needle is inaccurate, the light is useless. They call it a dummy light for a reason.
Steering Rack bushing if I recall. and it should be clamped down like on the other side. Oh, learn to use macro mode on your camera, lets you take up close pictures of stuff without fuzzy/unfocused results. It's usually a flower icon on most point and shoot's.
Redmill should also be around there. I'll probably be rolling in around 10, hopefully. It'll be fun to play in that parking lot without reverse...
I've noticed mine is really dim. Can hardly see it during the day.
I can't say for sure on these trucks. But Mazda put their BP engine in both the Miata (rwd) and protege (fwd) and really the only difference was coolant bypass pipe routing.
pull the plugs and crank it, be sure to have paper towels over the spark plug holes or you might make a mess.
Where does this run take place? I'm down to go!
So you got the vacuum routing figured out? I'll take more pictures if needed tomorrow, since it's dark here now. But yes, the A/C is still in the truck, and it blows nipply cold. It can be seen in the 1st and 2nd pics.
Perhaps I didn't search enough, or maybe this will be a good thread to start. But what exactly are the differences between them? I think I read that they have a bigger bore, and not a longer stroke? So to do the swap one would need the whole block... If it's just a longer stroke, should be able to take the crank out of one, and just put it in the vg30e block and call it good. I've done this with my old toyota supras engine, crank/rods out of the 7m and pistons/head of the stock 5m increases displacement from 2.8 to 3.0... Or is it easiest to just get a VG33e shortblock, and put the vg30e heads on it while keeping the stock ecu/wiring harness.
From the driver side toward the front'ish: Showing how it's routed to the vacuum switch, which appeared to be bolted to the valve cover: And the two bigger "vent" hoses. The one that crosses in front of the engine definitely goes into the passenger side valve cover, the other one disappears under the intake manifold and I lost track of it, but I would assume it does the same thing:
Looks like the two big ones go to the valve covers as a breather, I would assume. And the smaller one looks like it goes into a vacuum actuator switch. pics coming soon.
I'mma go peak at mine, camera in hand.
I notice you have beefier tires. Is your speedometer calibrated for the change in wheel/tire size? If not then your odometer/trip meter reading is going to be off, sometimes by a lot!
It's off 136th S by Sunset park on the Burien/Seatac border near Des Moines Mem Dr. Where the BMX track and tennis courts are, there is a dead end road. Got my first trail related damage today, got too close to a tree, haha! Don't mean to go OT, but here are some pics recently that I took: some ruts I made that my friends toyota pickup got stuck in, baha
Amazing Life From Stock Headight Bulbs.
silverton replied to sonyslave's topic in 96-2004 R50 Pathfinders
Nippon-Denso is probably what you're thinking about. -
damn, if I didn't work that saturday, I would want to go with. Oh well, guess I can get plenty muddy in the little pit I have by my house.
Who Here Gets Allergies In The Spring Time?
silverton replied to ac92pathfinder's topic in Off-Topic
clariton isn't an instant fix-it like other allergy medications. you have to take it once a day, and around the same time each day is best, and it takes a few days for it to take affect. I've had good luck with zyrtec though, my nose is starting to get itchy at work so I need to buy some, damn flowers. -
Put it up on ebay.
