23
Everything posted by silverton
it's safe to mix DOT 3 and 4, I think it has a higher wet boiling point DOT 5 is fully synthetic, and will turn DOT 3 and 4 into mush. DOT 5 can only be used on new, or FRESH brake systems.
That sure does sound like an awful lot of work! hah.
Yeah, it was 6.95 right before I posted.. haha.
you post whore! that's just short of 7 posts a day...
I have no idea what all this babble about 2 door > 4 door is. If you like two door so much, why not get a HB with a topper? And then the whole weight thing and the 4 door weighing more? I actually doubt there is more than a 100 pound difference between the trucks, as glass is heavy and it seems to me that both 2 door and 4 doors have similar areas of glass. And besides, isn't extra weight something that helps out on the trail?? Also, VG30E > VG30i
a quart should be plenty, but I would grab a small bottle JUST in case.
Thanks for the correction!
Truck looks nice! I see it all the time... what does SFD stand for?
I don't think they changed anything from the 96 to 96.5 model year. But I do know that pathfinder went through a front fascia change in 99.5
Are you positive you have a limited slip? with a LSD in lose gravel, etc, it should make two marks if you drop the go pedal from the a standstill.
Gauge Cluster Gear Position Lights?
silverton replied to ahardb0dy's topic in 90-95 WD21 Pathfinders
The gear indicator on my 95XE is on the shifter itself, nothing on the cluster. -
Brake pedal activates front marker lights?
silverton replied to 87BeachCruiser's topic in The Garage
sounds like someone, SOMEHOW, replaced the dual filament bulbs with a single filament bulb. 1156 and 1157 are the numbers. the dual filament bulbs have a twin post contact setup, and the single just have a big one in the center. so what I'm guessing is that someone forced a single filament bulb in there, which when the brakes were applied, also crossed power to the marker light circuit. -
How To Flush The Metalic Crap Out Of My Power Steering?
silverton replied to Mr.510's topic in The Garage
I second this notion. -
you could also get a collection of ball bearings or pennies....
on ODB2 vehicles there is, essentially, a bad cat code. The first o2 sensor is for the computer to adjust fuel trims. the second o2 sensor is to make sure the cat is still working, that is why it's after the cat. that is the only purpose of the 2nd o2 sensor.
You could always fix what's wrong with your rig... haha. Glad I've never owned an OBD2 vehicle. All OBD1 needs is a good cat, haha!
I'm also liking the manastash ridge suggestion after reading about it.
Between Elbe and Ashford, there are some pretty good trails. Here is a map: http://www.dogpoundoffroad.org/Maps/Elbe_ORV_Map.png Entrance is here 278th Ave.: Entrance to Elbe 4x4 hills
Rust is bad. Especially on the internals of an engine! If you want this engine to last, you need to get the crank machined and the block hot tanked and honed. And if the crank gets machined, you won't be able to use the old bearings, you'll need new ones. rings as well.
I have cyanogenmod's firmware on my phone, so as soon as he ports it over or whatnot. My 1.6 has tweaks from 2.0, but the phone isn't officially 2.X
Can't find this app in my market G1 user with a custom 1.6 rom.. This must be a droid/2.0 app
there is the possibility of sediment built up at the bottom of the tank as well.
Why Are Springs So Expensive?!?!
silverton replied to BigBikeMike's topic in 96-2004 R50 Pathfinders
You live in washington and parts are falling off?? All a resonator does is change the tone of the exhaust. Cherry bombs, are technically resonators. -
My last two "fill ups" have netted me ~20mpg, and that's mixed highway/city.
