23
Everything posted by silverton
Clean it? I just drive it to the mall and back, how did it get dirty??
Silly Heeper. Always listen to your spotter! Even if it feels wrong, they can see better than you.
Not the classiest of installs, but it works for me. I normally have it mounted to the back of the center console, but my truck was broken in to and they stole my radio along with the little screw things that hold it to the bracket.
That was actually a very good jump. It's the height that kills the components, not the distance. And that jump was clearly for distance and not height. Hell, I'd jump my Impreza off that! haha.
I'll take a picture later. Out of sight out of mind really. I forget it's even there most of the time, aside from having a 4 foot lightning rod on the tire carrier...
You still have to enter the discount code in the "how did you hear about us" box, but the codes are easily searched out on the interwebs. In the emails you get after buying something they even encourage you to share the code with family and friends. Now if the forum discount was 10-15% I'd be impressed. But as you said, they do still have to make money and their prices are usually the cheapest anywhere.
That was actually kind of cool. MrJim has a similar video on YouTube. Look up "air nissan" or something like that and it should be one of the first results.
It's the same 5% as anyone who buys from them gets, so it's really not THAT special.
Mine is "mounted" between the passenger seat and the center console.
The obvious is that you should have started your own thread. The other obvious thing is to make sure that the bulbs are good.
That two tone terrano pulling the rig out is one of our New Zealand regulars.
^^^ Beat me to it. Was going to say the exact same thing.
One reason I won't buy a new'ish Pathfinder
silverton replied to mikestewart395's topic in General Forums
In 20 years I hope to still have my current Pathfinder. -
It could also be that the spark plugs were not in one of the warehouses where the other parts were, so full shipping would need to be paid instead of just additional weight in a box already going out.
Cant determine my no crank, no start issue
silverton replied to RickWill's topic in 90-95 WD21 Pathfinders
I've heard of the relay itself, just didn't know they were notorious for failing. -
Your profile picture is very tiny. Can't really tell what I'm looking at.
2nd Chance - February 2014 TotM Nominations
silverton replied to RedPath88's topic in Truck of the Month
Just like in the first nomination thread, the resolution of your picture was too high. -
Never heard of that. I'd check the connection at the starter, and if that's good, replace the starter. Sounds to me like the solenoid has gone tits up. -
I stand corrected! A quick look at the FSM and it appears the Y-pipe is later on down the stream in to a resonator.
I let mine sit for months at a time, and every time it fires without a hiccup. That's something that can't be said for everything.
Good luck even making it to a mud hole -
Are these tires any good on the street? Curious
Yeah, those are diggin tires! a WD21 on 33's worth nightmare to be honest. -
I could be mistaken but I'm fairly certain that the Y-pipe runs under where the engine and transmission mate, so if the rear main was leaking...
There are a few places where these engines could leak oil on to the exhaust. It could just be the valve cover gaskets on the heads, which can happen they do go bad. Or it could be the rear main seal which is farther down and much harder to replace as the transmission needs to be separated from the engine. Hard to say if the axle and ABS light are connected, there should be a procedure for checking ABS codes in the FSM which is linked in a pinned post in the garage section.
For the record, I think projector's are the devil. I high beam flash everyone that I think has their headlights aimed incorrectly, and that's up to and including people with projectors who aren't on the same level pavement as me. But only because the headlights from a halogen equipped car at the same point does not appear to have two mini representations of the sun at the front of their vehicle. My 2001 Impreza with standard OEM halogen headlights has the exact same sharp cut, without the need of projectors.
