165
Everything posted by adamzan
KYB struts are fine but do not use the kyb strut mounts. They are terrible lol.
Seems to be discontinued at Nissan. You might have some luck calling dealers to see if any of the warehouses have old stock leftover. Otherwise you'll have to go to a wrecking yard.
I would not do that in these transmissions. They have enough problems with people using GL5 and a thin fluid like that in an older design transmission would lead to higher wear more quickly. Personally I use redline MT90 and it has kept mine alive for the 10 years I have owned it (had auto pathy's before then). This is just my opinion of course.
Glove box won't open. Any suggestions?
adamzan replied to BlueKrogan's topic in 90-95 WD21 Pathfinders
It got up a bit higher than that: -
Configuration for Sleeping in the Rear - up to 9' of space!
adamzan replied to mike1305's topic in 90-95 WD21 Pathfinders
It really is great. Back when my 95 was my daily I did this all the time for camping. Also get some screen and magnets, you can leave the windows cracked this way and not wake up to a nasty humid mess. -
I have flushed mine before and it helped a bit, my truck the previous owner had dumped stop leak in it. That crap is known for plugging heater cores. You have to flush it in the opposite direction of coolant flow as the sediment in there will be settled in the core. If I had to do it again I'd take it to a shop that has one of those power flusher things that hooks up to the air compressor. They work really well.
Where is the fuel pressure regulator on a '93?
adamzan replied to Flysilly's topic in 90-95 WD21 Pathfinders
The only beck arnley part I had a bad experience with was the wd21 cooling temp sender. I went through 3 of them from rock auto before I went to nissan and bought an oem one. -
1991 XE Center link wont fit on pitman arm
adamzan replied to pizuski's topic in New People Start Here!
I wonder if you could simply get a spherical bearing like the grassroots uses and press it into that CL. -
Damn that looks great. Wish I had kept my old VG33ER, would have been a great candidate for my wd21...
That happened to mine as well, not sure why but mine got stuck on hot instead which sucks in the summer lmao. These trucks it's normal for the temp gauge to only go up a 1/4 of the way. Take a temp reader at the upper rad host, if it's around 170-180F fully warmed up your thermostat is fine. -
Yep, gotta do the same on my xterra tomorrow. The damn doors freeze shut after every drive.
hose it down with some kind of lock lube and de icer. Common occurrence here in Canada lol
I hear ya. It took me several weekends to get all of mine done!
If you do it one link at a time you could certainly leave it on the ground.
LOL I know. It's a sheit show on there. I'm honestly done with it, if people want to talk to me they can find me on here... I deactivated my FB last week and kept the messenger though. Then this weekend I couldn't log into messenger, I had to re auth on my computer and when I did, it friggin reactivated my FB page.
How would anyone ever know if you welded it, doesn't QC only inspect if it's coming in from out of province? Ontario you only need an inspection when it's out of province or changes ownership.
The front shocks definitely are, the rear might be a different length but will bolt up.
What do you mean you aren't tired of seeing the same posts bragging about how cheap they could fix/do something? The first gen xterra pages are even worse.
It's crazy to me that everyone puts their entire lives on there.
When I had to do mine, I took the sunroof glass and new seal to a glass shop, they charged me like $20 cash to install it, still good 5 years later!
Try living where I live, where it routinely gets to -30. The 170F stat in my 95 just would never cut it so I put a 180 in it. Just enough difference to actually de-ice the windows.
Really it is starting to sway back to forums, facebook with their draconian moderation policies is really pissing people off.
It should have the instructions for that on one of the sun visors. Mine does. It's nice to take out in the summer time!
