93PathfinderWA
Everything posted by 93PathfinderWA
Hey you still starting tomorrow?
Hey, I should have work off and would like to see an sas build.
lock right experts help please
93PathfinderWA replied to dougdavis's topic in 90-95 WD21 Pathfinders
I went through the exact same thing a little while ago. Everything looked fine but it had a lot of backlash, so I had that setup at a shop but it did not change it at all. I read somewhere else that if you have an auto tranny, it will always be locked, dont know what you have though. -
Still planning on going. Not sure though. We'll see in the morning
I actually just got a gps from a friend. Need to hook it up but we used it in Moab last year and it worked well. Installing my locker tomorrow. Get to test all sorts of things this weekend.
im still in. bringing cold weather gear, food, and water though.
No. I actually enjoy cold weather camping. I just have to take a little 370 mile drive back to Pullman the next day.
snow wheeling at evans sounds good. probably wont camp though.
I should have a locker by then, and if everyone is locked then i think we should try something a little harder than Tahuya.
So can everyone do March 15th? That would be the only day I could make it.
But not everyone is rolling on 36's. I love the snow though. Just to let you know I went to Tahuya with some friends late in December and their was snow out there. How and why, I dont know but this was before anyone else got any snow. There was not much but it did make it a little more interesting.
I would be interested depending on where. Have spring break the 10-14th of March and will be back on the west side but otherwise am all the way in Pullman. Aires you got a locker yet?
I have taken my pathy on two long road trips since I have had it. The first was from Tacoma, WA to Death Valley, CA, total of 2,000+ miles. On the way down we drove for 23 hours stopping only for gas and it had no problems. The second was from Tacoma to Moab. We drove for 14 hours again stopping only for gas, wheeled Moab for the week and then drove back. I also take it on 3-400 mile road trips all the time and have never had a problem. With 213,000 I would jump in and drive it to Florida right now.
The ProComp ES3000 and Rancho RS5000 are the same shock according to 4wheelparts. The ProComp ES9000 are, i believe it is called, gas-charged which means that there is always pressure in the shock pushing down. This will give you a much stiffer ride since the pathy does not weigh a whole lot. I went with the ES3000 and they work decently.
Yah i am pretty sure that the top speed for 4lo is 25, maybe even 20. But honsetly if you have so little traction that you are using 4lo you should be driving nowhere near those speeds. With 4hi however i don't remeber ever reading about a max speed. I am pretty sure that I have gone over 55 though.
Hey, got all winter. I'll be at WSU also.
Hey I actually like the white. How exactly does the twin stick give you fwd and rwd capabilites but also give you a 4:1 ratio?
Hey since it is almost August and I might have some money to spend soon I was wondering if BP Armor was still going to be back into full production. Anyone have any updates?
Man hope you like the rain. Too bad I won't be around. I am going to your side of the state.
If you like the spoked look, then Procomp 51 series are the way to go. 4WheelParts guarentee the best price so do some searching and they will match it. If you have one nearby, no shipping. If you like the round holes, i.e. Procomp series 97 or Soft 8's, check out summitracing.com and their Cragar Soft 8's. $37 a wheel and only $10.95 for shipping. Problem is that they don't have stock backspacing but I went with 4.25 and 32x11.50 and they don't rub. I still don't know how to post pics so check out the websites.
Yah I did my body lift and it took a while. The problem with taking them a kit that is did not buy from them that I have found is that they charge by the hour and if the end up not having a part because you did not provide it, then they have to stop, get the parts, and then start again. So your pathy may end up in the shop for a while, if you end up having to wait for parts.
I can't go this summer but I went to the Easter Safari this year. My advice is to go with someone who knows the area or get a guide book because you can get lost pretty easy. I would recommend a locker if don't have one but were thinking of buying one. The trail ratings are based on stock jeeps with a short wheelbase and many have rear lockers stock, so even the easy trails have some hard spots with an open diff. For more info on trails and ratings go to http://rr4w.com/. Hope you go and have fun.
Good to hear that you got out. Buy a HI-LIFT if you are going to wheel alone. It has gotten me out of a few predicaments before, best $50 I have ever spent.
Well pictures would help if you could get some later but you might be able to just have someone pull you. If you are at an angle you probably would want to get pulled from the front since pulling you backwards might just drag it in the ditch some more. If not then find a hi-lift or a jack that is tall enough for you to jack your front tire that is in the ditch up to get the back tire down, if the ground is flat enough. If you can get the back tire to touch stack rocks under the front tire and just try to back out. In my experience you need to get the back tire down.
Link to Rocky Road Outfitters Link
