packie88
Everything posted by packie88
how old are the brake pads
Nissan Chromolly Axle Shafts
packie88 replied to SteeevO's topic in Solid Axle Swaps, Hardcore Custom Fab
im betting its a amatter of time... i normally used to play up at moon rocks adn funny rocks in the naches trail system... which is some of the best rockcrawling in washington.... so well see what happens. -
id say id wheel pretty hard im willing to try just about anything. lol. nope calmini gears (wish i did though) no atlas (wish i did though). and i have a rear lockright locker. i figure im pushing the limits of the axle shaft where it is now. -
im running 36s on stock shafts -
then i would do a 3 link wiht panhard or radius arm
ive got a 220v lincoln stick welder i got for 100 dollars and it welds everything i point the stick at. for cost effectiveness you cant beat a stick welder i would stray away from 110v 70a cause youll later wish you had just bought the bigger one and saved yourself the frustration time and money
same thing i told nismojunky.... in the end its not worth it if your gonna put all this time and effort do a 3 link with a panhard bar. " it would workbut youll lose articulation compared to a 3 link w/ panhard or triangulated 4 link. the reason being the link ends will bind under articulation but youll gain some back depending on the links end. the 5 link screads the load across more of the frame then say a radius arm. if you gonna put the design and effort to do a coil set up i would do it toward a 3 link with panhard for the front. 4 link front ends have steeering issues and would probably have to go to hydro steer because the tri 4 link would casue major bumpsteer....IT all also depends on what your using it for. are u planning on street driving it " you could theoritically do it....... would it be good for a front suspension. NO would it be good for articulation and offroading. NO is it worht the time and effort. NO Take your time doing these things right the first time not worth rushing into it and doing it wrong... something ive learned is that i wish i woulda saved up more and not gone with leaves but doen some type of coilover or coil set up from the get go. though while leaves are easy i want more . lol and take your tiem figuring out all the brackets and everythign as well as crossmembers cause if you dont youll end up redoing em and its a pita
are they available for disc brajes -
try a torch and burn it out
SAS got a axle but need help.
packie88 replied to GEOz2k7's topic in Solid Axle Swaps, Hardcore Custom Fab
yea i think a guy either on nissan4wheelers.com or the AC boards had em... not sure which ones... but i do know there is alot of good info on the nissan4wheelers.com website if you wanna check that one out as well and read there info but let us know ifyou have any more ? -
was plannin on makin it but apparetnly my boss thought it was more prudent that i work that day... dont know what she was thinking
Weight be Damned - I need a BOV - Zombie Killing Rig
packie88 replied to GreyAliens's topic in Off-Topic
the tent is an arb dealio and is about 1200 dollars. -
yea it might have to do with that and the more weight on the front end and rear. and u know it B i cant name the number of times at the gas station or wehn im walking or getting in the car people are like so hows your jeep handle in the winter... im like umm i wish u knew how to read
mpgs on mine went from like 17-20 to 8-10....lol but i dont drive it often... basically to the trail and back or occasionally to teh grocery store to see people faces like WTF is that
on my sas i have a set of 33 road tires that are for the road only.... for offroad i have a set of 36 swampers... clearing 36s with a spring under will require you to cut you fenders on all for corners to avoid rubbing and even then you will probably still get a little rub.
im excited makesure to take plenty of pictures
what are you taking about not understanding what your trying to say -
alright here you go ill hand rancho rs 44044 http://www.jegs.com/i/Rancho/801/RS44044/10002/-1 rear springs i used basically any progressive early bronco 5.5 inch coil http://nissannut.com/projects/long_arm/ thats the rear link page i used to gather my information http://nissannut.com/projects/SAS_WD21/ and what i used for the front i kinda used those a s a basis of my research... search around nissannuts website he knows alot and has posted it for others to see and use -
REGULATORS MOUNT UP..... thanks pezzy
ive used the bosch ones for awhile now and see mto be doing there job... the fram ones are over priced adn cheaplly built not to mention the fact that they are th lgihtest cheapest things ever... ive also like the napa ones.
crumple zones and pathfinders a re the @!*%.. they absolutly have savedd lives i think someone should show that idiot who sued nissan how lives are really saved and that shes lucky to be alive
what 87pathy said is exactly what i have going on
i went leaves cause its cheaper and now i wanna go to some type of link/coil setup
we talking this coming saturday... or what dates... casue im down to help
