Filthy Luker
Everything posted by Filthy Luker
Rims refer to the outside edge ("A RIM") of a wheel.. Unless you're planning to buy the cut out RIM of a wheel without the spokes and the hub, perhaps you should reconsider your designations.
Perhaps its time to rework the pinned/stickied/often discussed sections into something more comprehensible for newbs. I suspect the follow up question about to be asked here is about rear spring options.
Wrong vehicle bud. Any realistic power gains require spending some real money. Also invest in the "search" function. I hear it really delivers.
differential ratio Is it easy to change?
Filthy Luker replied to firemandan_nz's topic in 90-95 WD21 Pathfinders
also calmini@ http://www.purenissan.com -
how does the CALMINI 3" suspension work
Filthy Luker replied to Viper929's topic in 86.5-89 WD21 Pathfinders
You can SAS it with coils. -
I don't think they have Xterras in New Zealand. You'd have to check around if any Navaras there came with 4.9s... Honestly don't waste your money on getting different gears unless you go for the t-case gearsets that are available. It's perfectly fine to run the stock diff gears with 33" tires.... spend your money on making the front end more solid to take them without blowing up the centerlink. -
OK so i failed to deliver on the vodka part but I drank scotch all night long and completely satisfied left right and centre two eastern european girls... while screaming "all heil Mother Russia!" which added to the hilarity of the situation because they weren't from Russia at all. I did learn some Swahili tonight tho as they're both PhD students in foreign languages.
I drink vodka for you tonight my e-friend Iron Locust.
HAHAHAHAHAHHAHAHAHAHHAHAHAHAHAHA
Happy B-Day? Why isn't this topic pinned as well? :confused:
Happy b-day.. how come this isn't pinned?
That means I get the same treatment then...? sly
Why is this pinned and other happy b-day threads aren't? :confused:
Couple of more years and we'll be able to take you out for beers and strippers! Happy Birthday Youngin'!!!
Is your steering system stock? If so, your centerlink is probably chewed up to bits.
Meh just get a decent filter next time. Get a Nissan one or shop NAPA or something. When you get a filter relocation kit, get the Ford Motorsport ones from a Ford dealer.
Well if it's flooded the simplest way to fix it is to just take out the fuel pump relay, crank it until it catches. Then slap the relay back in.
How badly is it banged up? I'd be more worried about damaged oil pickup and low oil pressures.
Will somebody PLEASE think of the children?
He should have at least given a link to nissan4wheelers or something. sly
Impossible. Salesmen usually know how to spell the name of their merchandise.
Lift it up... put real axles underneath and 35"s on it. sly
35"s on IFS? Sweet lord... Move the bumper up bro... Otherwise.. ughm.. start looking for a spare front diff? I've seen two grenade already on Xs...
here's a page from this: http://madmudders.net/WD21FSM/EL.pdf hope this helps....
3/16"s will be easier to work with and more than strong enough.
