Everything posted by headpeace
what fluid is recommended for the front diff 93 pathfinder?
I didn't lose hardly any when I did it, you wont find J matic anymore, S matic superceded it
Did the high pressure line fail in a way that would cause over-pressurization?
Alright, I found that the leak was at the connector which has a copper washer and then the banjo bolt holds it all tight. I thought surely the copper washer wouldn't have failed but I replaced it anyway. That fixed that leak - cool. So I started it up and turned the wheels back and forth and go over to look to make sure everything is nice and non-leaky. WTF! now its leaking from the high pressure hose where it connects to the metal line AND the low pressure hose where it connects to the pump!!! Any ideas on WTF the problem is?
Haha, I didnt see the "Do not disassembly", musta been a translation error. Well that sux, what does the "X" next tot the o ring mean?
i was thinking maybe the maxima?
thinking of going the JY route, anyone know if there were other vehicles that used this pump other than the PF and the pickup?
Thanks B, its leaking from the connector bolt assembly. I wonder if I could find the parts to replace the innards of that, probably that o-ring
any fsm download that's a pdf and not rar?
also, anyone know off hand how much ATF I need to replace the fluid?
as far as I can tell it's just the tensioner and one bolt, does that sound right? I can't find my damn haynes manual because I rely too much on getting my info here, I know I have it but haven't used it in years. I just drove it around and got back home and it's leaking pretty bad, gonna have to go ahead and put a new one on.
Thanks RedPath and Rebelord, after finally getting some time to poke around in there the fluid was low but I looked around and the pump is leaking around the top where there is a big 15/16 nut. It's not like drip drop leaking but I can wipe it dry and 5 minutes later it will be wet around that seal. I tried tightening that nut to no avail. I filled it back up and guess I'll limp along with a slow leak and keep my eye on the fluid level until I can replace the pump. Any how to's on the pump replacement? It looks fairly simple but I could always use tips and tricks.
is it likely old fluid or does it sound more like the bearings going out on the pump?
Anyone happen to know where that thread is, I'm not finding it
Today I started to notice when I turn my wheel either way I can hear a low pitch moan sound. I can feel it in the steering wheel too. Is this the power steering going out?? How do I replace the fluid, turkey baster suck it out and add new??
I don't see either of those on the diagram
Where in the hell is the rear diff fill plug?
headpeace replied to headpeace's topic in 2005-2012 R51 Pathfinders
feel like a dipsh#t for that one, it was plain as day. I guess I just wasn't paying attention the first time I looked -
thanks!! -
Just as it says
so which one is the starter relay, I didn't see it labeled
good info, thanks
What are the most common place's for oil leaks on the VG30E?
so it is possible to do the crank seal without pulling the oil pump and kinds of other crazy stuff right?
yep, according to my VIN my 93 was only about a month off from getting the round tooth
