90seven
Everything posted by 90seven
  1. V8 with a SC. That should give the JGC SRT a good run for its money.
  2. I just purchased this. Awaiting its arrival. Is the mileage you received them still consistant today? ProTex Twister. I got two, one for the Pathy and one for the Alty. I've always wondered how it worked. The concept of it sounds convincing enough. And its cheap, so what the hell.
  3. Not to veer off the topic, but its amazing how one superstitous saying can make it around the world with different interpretations. In the U.S. its "knock on wood". What its like anywhere else?
  4. So, I went back today and tried again... after almost 3 months. I figured out why it wasn't working the first time. You know when you leave the keys in the ignition or leave the lights on and that *teeeet* *teeeet* noise warns you of something? Well, whenever that noise happens when I insert the key it doesn't work. I found out that it has to have no noise at all when I insert it. Having said that, I finally got the hazards to flash easily after inserting 6 times in 10 seconds. When I switch the ignition to ACC and press a button, nothing happens. I'm looking tomorrow for another battery. I purchased it from eBay so it maybe its a bad battery. Its a knockoff, lets hope that's not the case. *Please be the battery...* Wish me luck.
  5. Standard towing for the Pathy is 3500lbs. Maximum is 5000lbs. Payload is 1175lbs. Keep in mind that if you add payload, your towing max is is also affected. If you're equipt with an Auto Trans and 4WD, you'll be better off towing. Try not maxing the vehicles weight. You may lose control, going down the Rocky's. Check your brakes/brake fluid and coolant and radiator condition. Good luck!
  6. Keep the offset the same, just get a different backspacing. You have to talk with someone that knows it though. (Discount Tire had no clude what backspacing was since it doesn't show up on the computer)
  7. I believe the stock offset would be 20 for the R50s.
  8. Have you tried Ji Wolf Technology? Like Stillen, they specialize in Nissan vehicles. JWT Pop Charger
  9. Our Pathies don't have that neat little flash and honking when its armed from the remote. Its armed though.
  10. I've also have an issue with mine since I had my 31s. My truck pulls to the right so I'm forced to steer the wheel to the left a little, [(\)] just to drive straight. I too had it aligned. I was told that its probably my suspension. Have you checked your suspension lately?
  11. Well, my 31s finally busted up my wheel well. I say when you get the tires you want mounted, drive around a bit and find out where they rub and then trim as soon as possible. I'm trimming mine this weekend. [i've been seaching for Pezzy's (I think its hers) pics when she had her fenders trimmed so i can cut mine the same way. Any help..]
  12. What the hood pin switch? Is that the button that lets the truck know the hood is shut, just like each door has one? If it is, I guess it is bad. I held it down for about a minute and it still alarmed. A couple of weeks ago I installed some speakers and couldnt get the power window plug out so I just disambled the piece. It was a PITA to put back together. Every now and then when the window doesn't work, I have to tap on the door and the little balls fall into place and it will work again. You think that's causing the alarm? Well, its my weekend and I finally noticed this issue. So, in the meantime, how can I fix this "hood pin switch"? Does it have to be replaced? I really wouldn't like to pull the fuse from the alarm, but since its been happening I've been disconnecting my battery at school/work. At home I just leave one door unlocked. So I guess I am still "pulling the fuse".
  13. My alarm is going off like crazy. I remember when my 240SX kept going on it was the battery, I think. So today I went and bought my truck an Optima Yellow Top! [ I had to] But it still going off. I'm in class and there was an annoucement for the owner of a white "jeep" [errrrrr] to please disable the alarm. So I ran out and disconnected the battery. Whats going on?
  14. Hahaha, that was so damn expected. I was thinking about that on my way home from school last night, and knew someone was going to make a comment on my lack of half a brain. "Why not just use the digicam?" Its hard to see but... Sticker1 was the first one, the orignal but she said that it was hard to cut. [Jumping to Sticker3] Sticker3 was the second one that she made and I think the best of them all. [but when she handed it to me I noticed they were different and told her. Since she thought one was for me and one of for a friend that it wouldn't matter to me. But I told her that both were for me and I wanted them the same. She then made another one which came to be Sticker2] Sticker2 was the third one she made and I left without looking at them. But if you look closely, its a lot closer to the top border than the others. Each one is a different size. [[[NOTE: ONLY THE TOP LINE WAS ALTERED, ALL OTHER TEXT REMAINED THE SAME]]] Not a big difference but enough to annoy me. When I get some spare change, I'm going to check back and have her make me a new MATCHING set. The current one is available if anyone wants it, but if it not then i'm just going to find something to stick it on like my brothers JGC HAHA! Pic kinda sucks, I couldn't find my camera, so I made use of my webcam.
  15. I'm still figuring out a way to scan it lol. I have an All-in-One connected to one of my machines. The machine is just used as a backup storage for my home network and to share the printer. The machine doesnt have anything connected to it like a monitor, mouse, kb, so I'm trying to figure out how to share the scanner thats available. Theres a third-party proggy called RemoteScan but is there another way without third-party programs?
  16. Do you still have the stock headunit? If you have an aftermarket headunit, just bypass the amps and run them off the new headunit.
  17. It cost me $7.00+tax for one. So thats about $7.54. That covered the "custom sticker fee." That was for my small one though. If I order in bulk, maybe I'll get them for the same price for larger stickers.
  18. I've been thinking of replacing mine for a while as well. Just been procrastinating. I remember looking through the haynes manual and only seen one filter. No other filter is present. Speaking of dust.. I live out here in Vegas.. I better get to it.
  19. Ok guys... I finally found someone locally to make mine.. If anyone wants some they are available. She currently doesn't have the reflective stickers but if theres a request, she'll get a roll. Anyone interested? I made some for myself that fit inside the fixed glass section of the rear doors, which is 8.25in long x (I'm not sure, didn't check) 2.25in wide. If you have a different design, or larger size, attach the image, and font if possible. I'll get them made and shipped.
  20. She's a beaut. With that said. I hope you have really long arms when stopping by the drive through.
  21. B-E-A-UTIFUL! Now for some matching wheels.
  22. I enforce that same rule. NO EATING OR DRINKING IN MY VEHICLE! (Notice there's no "Please")
